stasz
I want to record a 3-piece band- drums, acoustic guitar, and piano (plus lead vocals)- all together in a single room. I have a room with high ceilings that is good for recording, and I've had pleasing results in the past using a Zoom H2 recorder for some demos.
I'm using a Mackie Onyx Blackjack, so I only have 2 inputs. My idea is this: would I be able to get some good results using a pair of Behringer ECM 8000s to try and capture the room sound? Would it be able to capture the sound of all the instruments in the room? (I understand the ECM 8000s are intended to test the noise floor of your recording setup, but I've heard that they're also good affordable omni mics for music recording)
My next question is: Matched pair of ECM 8000s for stereo recording, or could I get away with a single mic? I ask because I would like to record vocals on one input and use the other input for a single ECM 8000 to record the room sound, but there is also the possibility of using a pair of ECM 8000s and overdubbing the vocals later. Which do you think would sound better? If I record the room in mono, is it going to sound unnatural?
Or, if you would recommend a better omnidirectional mic for capturing the sound of a 3-piece band playing in the same room, then I could look into something else (I have not yet bought the ECM 8000s). Thanks!
