because the high end stuff does have humps in the response curve and slower transient response than studio monitors.
darrin_h2000,
Sorry to disagree. Even though it's true that most audiophiles tend to believe the loads of bullshit fed to them by sales people, this claim of yours about the difference between Hi-fi and pro audio is really not accurate.
Since there's such a wide array of a design approaches in Hi-fi, it's almost meaningless to make a blanket statement. But, considering a significant percentage of Hi-fi speakers are electrostatic or ribbon designs, which is virtually nonexistent in pro audio, you'd have to conclude Hi-fi speakers generically have better transient response than pro monitors.
"Flat frequency response" is also nothing rare in Hi-fi. Of course, the method used to measure that response and how well this actually translates in a room is always suspect. But it's no more suspect than the claims made by most pro monitor manufacturers.
Just looking at the drivers used in a loudspeaker can tell you a great deal about its 'potential' performance.
[It's like looking at the speed rating on the tires of a car. It doesn't matter what kind of engine or suspension you have, if your tires are only H rated you're never going to take a turn at 180 mph (290 kmph) and live to tell about it. Now, Z rated tires don't mean much if they're mounted on a stock Honda Civic, but at least there's the potential for modifying the car]
Anyone familiar with designing loudspeakers will instantly recognize the drivers used in the vast majority of pro monitors (save for some of the newer in house JBL designs). They are variations on common OEM designs made by a half a dozen or so big driver manufacturers. Other than a few exceptions like Quested, most of the drivers used by pro monitors are similar to those used in Mid-fi (at best) consumer speakers like Polk and Boston Acoustics.
This is not to say that excellent results cannot be obtained from such components, or conversely, poor results obtained from badly implemented expensive hi-end components. It's just that, for example, the Vifa dome tweeters and polypropylene woofers used in Event monitors have inherent performance limitations which cannot be overcome by even the most skillful designer
[Limit a Porsche designer to regular family car radial tires and there's only so much he can do].
I'm not suggesting that people go and trade their monitors in for Hi-fi speakers. I don't see many out there that would be well suited for the purpose. My point is, there's a great deal of hype and misinformation in both Hi-fi and pro audio (though more so in Hi-fi). Just because a pro monitor manufacturer spent a lot of time in an anechoic chamber tweaking for a flat frequency response doesn't say much about the other, far less trivial, aspects of the monitor's performance.
barefoot
