M
miltslackford
Hi
I'm trying to find a theoretically sound way to record my two amp set-up.
I use two studio 100 HH amps both are twins. I need to use both amps as I split the sound from my effects into the two different amps so that I can do things with the pitch shift and use different sounds in each amp.
Because I'm doing everything myself and I have to set up the amps and recording equipment and effects every time I want to use the room I've got, I'm trying to keep the technique basic.
So I've got two 57s, pointed straight at the right cone (about two inches off-centre), and 1 foot back from each amp. I've positioned the mics and amps 3 feet from eachother. In this way I'm trying to use the 3:1 rule I read somewhere and to get the mic from one amp to be the ambient mic for the other.
Can anyone suggest other ways of doing this micing procedure, or anything I might be doing wrong? IN PARTICULAR - would I be better off disconnecting one speaker in each twin to minimise the wave interference?
Thanks!
Thanks!
