recording problem
  • Thread starter Thread starter JB181
J
JB181
I having a problem with cubase recording late. For example, I'll record a verse and double up that play back fine. Then I'll record a hook and it comes in late. Why would this be happening? Like I said it records fine for a few takes and then it gets off and no matter how many times I retake the part, it's not on point like it should be. I have adjusted my sample rates and latency values. Any suggestions???
It's a tipycal latency problem,and a bad pc set and tuning for audio apply.
Tell me wich type of pc..set..and audio card.
me too
I have this same problem when using Nuendo.
COmputer is:
XP1800
360 megs SDRAM
40 GIG HD (7200)
AUdiophile Card.
I dont get this problem when I use Cool Edit Pro but with Nuendo I get lag. Ill record a track and then I'll go to put down another track and then when I'm done I go to playback and my second track is behind by like a 1/4 of a second. I dont know if there are settings in Nuendo I need to change to fix latency but this isn't a problem in cool edit pro. I know my computer isnt the best but I shouldnt have these problems.
Anyone?
Are you using ASIO Drivers in Nuendo (I thought you were using Cubase ) ?
What buffer size do you have the audiophile card set to ?
Im using Nuendo. THe original person that posted is using Cubase. I dont think I was using my ASIO drivers. I'm farily new to recording and to the Audiophile so maybe that was my problem. Right now my buffer size is set to 512. Should I set it up higher? Should I check teh box that says "use window default for MME? Thanks for your help.
TYler
Asio set up is only very important after a few set up that you have to make on the windows program.
So now leave asio setting as this and try some correction in windows.
ex..http://www.musicxp.net/tuning_tips.htm
Try to make all point that are very important,attention when you make modification...very attention.
So only after making this...you will have a music pc professional
setting and try to found correct latence.
Sorry Vedder, my bad.
Not totally familiar with Nuendo, but I do know that the larger your buffer size the larger your latency will be. You can test your system by trying larger buffer sizes, but with your RAM size a larger buffer may be needed.
hmm, hope this helps
okay, this helped for me. i adjusted my driver settings under, devices, device setup, vst multitrack. pick ASIO DIRECT X FULL DUPLEX. that seemed to work for me with a pro card and also for my friend with his soundblaster. it saves a lot of time from having to slide the tracks over until the or where they need to be.
