EddieRay
Can you take direct outs from a FOH mixer, run them through another mixer, then record to (--your media of choice here--)?
Just last weekend I recorded a "mini concert" at a local venue. I brought mics and cables in case I needed them but ended up taking feeds of the board (Carvin 24 channel) for the FOH mix. I had not done that before.
I had the sound guy send all 3 vocal channels to EFX2, and 5 drum channels to EFX3. I recorded to ADAT from the 2 EFX sends and from the inserts for the guitars and bass. The signals were a bit hot for guitars and bass so I slipped in an RNC between the board and the ADAT. Having only 2 channels of compression I was unable to treat one of the guitars. Fortunately the end result did not have any bad clipping despite the ADAT meter showing lots of red for that track.
The bottom line is that I could have done some better planning for this. I'm thinking I could have run the inserts and EFX sends from the main mixer to my own board, giving me better control over the recorded levels. But can this be done? I don't know how often I'll be doing this and I'm not in a position to go experiment beforehand. Thanks for comments...
Thanks mucho!
