T
tom18222
yes
Should i record them all at just below peaking and mix after, or should i set the levels first? i assume the first.
RAMI said:Yes the first. Except that you want to record a lot lower than "just below peaking". (I'm assuming we're talking about digital recording).
ez_willis said:I've heard this a lot, by people that know waaaaay more than I do, but I can't recall why it is so important to do so. I'm not questioning it, I'd just like to know why it is bad to get each track just below peaking.
Vullkunnraven said:If I may Hijack this...
Any recommendations for those of us tracking on ProTools LE who only have PT's digital mixer to monitor peaks? Is getting a dedicated outboard VU meter (provided your pre's do not already have one) recommeded? If so, any particular units come to mind?
I struggle with peaks and levels all the time while tracking...
Thanks,
Ari
Thanks,
Ari
I think since drums are so percussive, you need room to keep some dynamics. If you kill the dynamics by making everything too hot, it can sound fake. With a good setup, I'm sure right below Zero will still sound fine, BUT.....you want to make sure that you don't overdo it. It's like a good, distorted guitar. Really loud, it might sound good solo, but how will it fit in a mix? In the mix is where it's most important. You will need some headroom for the entire mix, so having drums recorded near 0 is not really necessary. If you get a good recording, near zero, it should work. But you should probably always err on the conservative side. It's easier to deal with.Dogman said:You should record leaving yourself some headroom...just in case.
ez_willis said:I'm in the process of recording drum tracks for three songs.
I use 7 mics that go into my Tascam tm d-1000(digital mixer), then each of the 7 tracks are brought into Logic via a Hammerfall HDSP 9652.
Why is it important to have each of those 7 tracks well below the peak?
I think you may be onto something with the eq boost. Anyone else have anything?
