Mke, First what type of gear do you have/looking to buy. A good/basic setup for a drum kit to record that I would reccomend would have:
1. Kick Drum - Shure Beta 52/51, AKG D112 (inside kick drum pointing halfway between the beater and the top of the ring)(Pan Straight up Center)
2. Snare Drum - Shure SM57 (keeping the mic out of the drummer's way can be difficutl sometimes with different setups...before you start go around the drum and try different mic positions while your drummer hits it...maybe about 2-3 inches off the head at a stong angle pointnig towards the top edge of the snare)(Pan to about 10-11 o'clock)
3. Toms - Sennheiser E604,
Shure Beta 56A (tom micing isn't too hard, keep the mic head off the drum a couple inches pointing more towards the edge than the center. You might get too much tone from the center.)(Pan around as you see fit, moving left to right)
4. Overheads - Shure SM81 ("One Left/One Right", "One Close/One Far" - Ther'es a few different things you can do here. Keep the mic about 2-3 feet above the kit for your close, and if you do a far mic, try differnt heights to see if there's more room reverb that comes along with it.) (Pan about 3 o'clock and 9 o'clock if you're doing a left/rght setup, and a few degrees off to the left/right for the close/far mic technique.)
wow I kept on writing, hope that helps!!! I didn't realize I like Shure so much...
