K
killer_deep
Hello All,
I wanted a simple way to record my drums for cheap. The idea of close-miking everything seemed like overkill for my needs, and I've heard that John Bonham's recordings were often done with only 4 mics.
Based on my shopping around, it seemed like the Blue Kickball was the cheapest way to get decent sound from a bass drum ($49.99), and Karma, was going to give me the best bang-for-the-buck overheads (a matched pair of Karma K-10s was $99.99). I've got a GLS Audio ES-57 coming for my snare, but I'm not even sure that I'll need it. The recording interface used is the Presonus Firepod. The left overhead was panned left (9-o'clock position), and the right overhead panned right (3-o'clock position). I did no EQ-ing, adjusting, or whatnot.
So, here are the fruits of my labor:
Forgive the sloppy playing - once again, I've only been playing for 2 years, and I hadn't warmed up before pounding this out. The overhead mics are in the Recorderman configuration, and the kickball is right in front of the port on my bass drum resonant head. There's a towel in the bass drum touching both heads (although I normally play with no muffling).
My drum kit specs and set up are here:
http://www.pearldrummersforum.com/showthread.php?t=218629
I would appreciate any comments, critiques, suggestions. One thing is clear though: there's nothing wrong with value picks! Especially those Karma K-10s... absolutely outstanding overhead mics to my inexperienced ears. Hopefully these sound samples will help others that are in similar positions, looking for cheap, value recording equipment
