pisces7378
Since I am having so much problems burning a fecking CD with any Logic Audio .wav file (it always sounds fine in Win Media Player, but somehow when I burn the finished stereo .wav file to CD there is a lot of digital noise) I remembered that I have just bought a SONY MiniDisc player/recorder to use just for listening to music in the train on the way to work. Now that thing can record a CD beautifully with the "line out" jack from my old DiscMan connected right into the "line" in" jack on the MiniDisc recorder/player.
Now the only problem is... my Delta 66 with the OMNI does not have a clearly marked "line out" jack. I have all kinds of headphone outs, monitor outs, direct outs, effects sends etc... but nothing saying "Line Out". Now, I have tried to record to MiniDisc via the headphone jack, the direct outs, and the Monitor outs... and there was always SOMETHING wrong.
The Headphone jack totally removed the lows and the whole song clipped like hell the whole time... I probably nearly fried my MiniDisc player!
But they all did that. Every single "out" on my Omni was too hot for the MiniDisc. The MiniDisc recorder doesn't have a trim knob or a Pad button (come on SONY, ever consumer needs to have at leat a pad button if not a high end trim knob
What would you guys suggest I try?
What made matters worse, is that I have some really nice BeyerDynamic DT990 headphones... and I used them to "set the level" before I pressed record on the MD recorder and play on Logic. The DT990s have an extremely high empedence I guess because when i tried to listen to the same mix with normal SONY headphones... it was SCREAMIN. (just a little side story)
Anyway... any suggestions?
