			timboZ
When I set the mics up this way the mic that should be over the right sholder of the drummer ends up next to the drummers right ear, and I get a lot og headphone bleed.
What am I doing wrong.
			mrface2112 said:likewise, don't feel limited to the "recorderman technique". put the overhead where it sounds best--not where some online "how to" tells you to.
			MatthewRedStars said:One suggestion i read was that if headphone bleed is a real problem then try wearing proper builders ear defenders with ipod style earbuds underneath.
			Greg_L said:The important thing is that they're equally the same distance from the snare and kick and pointed directly at the center of the snare.
			I do mine about 2 and 1/4 stick length away, and my right O/H is roughly 6-8 inches from my ear. I'm not having any headphone bleed problems though. Maybe yall just need some better cans?timboZ said:But when I did have them that way the mic was within 3 inches from the drummers right ear. I moved the snare a bit and went about 2 and 1/2 drum sticks frome the snare. I'm still playing with mic placement to get something I like.
			Greg_L said:Just move the mics a little further away. The important thing is that they're equally the same distance from the snare and kick and pointed directly at the center of the snare.
You don't have phasing issues with the snare? Are you using omni-directional mics or something?Berberman said:I have one OH pointing at the snare, and the other at the 14 and 16" toms. This way i get more of a stereo image of the whole kit, capturing the lower toms better since I don't have them mic'd. The sound waved still get from the bass drum and from the snare to the OH's at the same time since i have them at equal distances. (two drum sticks from snare, and i set my snare higher than the usual)
Another idea is to set the OH's a little higher than you're used to. I'll repeat what the others said about experimenting and getting the right sound to your ears.
Like Greg, I'm surprised this sounds good. But if it does...it does.Berberman said:I have one OH pointing at the snare, and the other at the 14 and 16" toms.
			Greg_L said:You don't have phasing issues with the snare? Are you using omni-directional mics or something?
