FALKEN
as per my fostex e-22, which I have been mixing down to. I love it to death. I also love having several 1/2" formats and being able to swap tapes. I think I just love 1/2" tape. That being said I am also a perfectionist and there is a small issue driving me nuts. I know I always come here with these "small issues" and what more can a few guys on the net do. but honestly you all are very helpful and always seem to point me in the right direction. And I am always thankful.
My problem is that the record eq doesn't do anything. Which in itself makes no sense to me, because the playback eq works fine. And it is the same story on both channels; playback eq is fine; record eq does nothing.
While recording various frequencies and monitoring playback you can see that the channels are off from each other, but only by say a couple decibels. Since everything sounds ok, I've been working with it.
However, it is coming time again to be sending out demos, and I want everything to be perfect. So I've been working on some mixdowns, and what is happening is that one channel, compared to the other, has a louder RMS, but quieter peaks. by a couple decibels. It is driving me crazy. The drums shift to one side (because they represent the peaks) and if I boost the other to make them centered then the material on that side is too loud. I thought about it a long time and I think the peaks are hotter on one side because it has more high frequency and the RMS is louder on the other side because it has more low frequency. This seems to make intuitive sense, also. I did this test with a mono mix, just to avoid any differences a stereo mix might cause.
So, I guess I have three options. I could go to a studio, but honestly, with the current setup I'm running, and the years I have invested doing this, I think my recordings sound way better than any local studio. I could try to fix it, but I wouldn't know where to start. How could it be that the caps went bad, but only on the record eq, and on both channels on top of it. It doens't make any sense. A third option would be to adjust the playback eq to even things out. This would get things very close but my tapes wouldn't play back properly on any other machine.
So, I turn to you wise ones for advice. Did I overlook something? What would you do? Thanks in advance.
