Reatune
  • Thread starter Thread starter timtimtim
T
timtimtim
Member
I'm using Reatune to correct my vocal. The Automatic Pitch Correction works very well, except where my voice is so out of tune it corrects to the wrong note. So I'm trying to use Manual Correction to fix just those notes which are wrong. But though it corrects to some extent, it doesn't fully correct the note, it takes it to somewhere between the correct note and the wrong note. These out of tune bits are quite brief, just a fraction of a second. Am I missing something? Have I got it set to 50% correction or something like that? I've got the attack time set to 100mS. It's at 100% wet.
Do you have the correct key and notes set?
If your pitch is that far off, consider retracking?
I've found the manual correction to be a bit hit and miss...
