Reason MIDI Board
  • Thread starter Thread starter MITM
M
MITM
Hi all, i have a problem
I work with reason 3,0, and download Reason MIDI Board, the problem is that she does not connect, I do not have idea of like doing syncronizacion
I have 2 sounds cards of Realteak and creative
Thnks
Its a qwerty software keyboard based on midi yoke.
I just tried it and you need to DL midiyoke from midiox.com and set it up correctly. Then run the midi board, select one note (or whatever) and the midi yoke port and that should be it. The midi yoke ports will appear in reason. If this will be it for your keyboard then set it up as the master control surface. Add an <other> as the master keyboard and choose the yoke port as its channel
