T
talontsiawd
Ok, so i have been using my bedroom as my studio. A room has opened up so i am going finally have a room purely for studio use. I plan to use the same room since it is the furthest away from everyone else (noise). Anyway, right now, my main problem has been the fact i couldn't do much acustically for it because i didn't have the space due to things i need to live here. Obvioiusly now i can work around it. I'm having a bit of trouble because of the odd shape of the room.
Here is what i'm working with right now (note-the ceiling is sloped starting around 7ft at the window to around 12 around the dor area, more or less)
My current accustic treatment are two 4in x 4ft x 4ft 703 pannels in the tricorners abover my desk and two 4in x 4ft x 8ft 703 pannels behind my moniters. This is because this is basically all the wall space i have at the moment
Room construction....Approximately 14x12.5ft. More or less. Sloping ceiling going from 7ft to about 11ft (highest part of the ceiling is at the top of rendering). Hardwood floor. All walls are insulated, drywall. 1 door, one window, one closet.
Ok, now for the rearrangement. I don't need a bed, bookshelf, any shelfing on the wall etc.
Lets start with what my actual uses are. I mostly create instrumentals so that is the priority, accustically. Pretty much mixing, etc. So i am defineatlly willing to build everything around the moniter location (since i now can as opposed to before). I also record vocals on a decent basis. I'm not sure it's worth my money financially to do much treatment as i don't record myself, nor do i have "clientel". So basically, monitering is of the upmost importance, and since i have only one room, that is the priority over any "vocal treatment".
My current problems i have...First, what is behind my left moniter is totally different from my right. I have that space in the door way area on the left, and a wall/corner on the right. Before, it was my only option space wise. Second, lack of area for treatment. I just couldn't fit it in. 3rd, my desk is at the high side of the sloping ceiling. I have been told this isn't optimal.
What i can/cannot do. I can move any of my furnature and existing treatment. Obviously or i wouldn't be rearranging
. As stated above, i'm willing to do everything based on moniter location that is possible. What i can't do is any construction. I cannot change anything, make walls, etc. I cannont make a plug for the window (it faces the street). I only have about $500 max budget, so 703 pannels will probably be my best friend.
Anyway, sorry, long post, i'm just very excited to have a purpose built room so i want to deal with everything i can while most of my stuff is out. The is also a bit oddly shaped so it's hard to research when 90% of the information you find is for rectangular or square rooms.
