Reaper used with Tascam US 1800 Interface
  • Thread starter Thread starter rwaynem
R
rwaynem
I have a setup of 8 outputs from Roland TD-30KV Virtual Drums to Tascam US 1800 interface. From the interface to computer via USB. Using Reaper as the DAW. I am getting sound levels in Reaper. The problem is I'm not getting audio back to the headphones at the Tascam Interface. I can hear audio when the Mix knob is turned to INPUT, but not when turned to COMPUTER. Any help would be appreciated.
Just re-read this and I think I misunderstood. I thought you were talking about input monitoring, but maybe you're talking about playback. Make sure you've set the right routing from the track to the master bus and from master bus to the appropriate output on your US1800.
Sounds like the best answer there.
