Clam Soup
Project 49
When you set about to mixdown in cubase, you "write enable" whatever track you are wishing to secure ... are there preferences over which element should be the first to mix down?
Is this a mix question or a how does read and write work question?
Because if it's a how cubase automation works, you enable write to write the automation and read to read it. If only read is lit, then it makes it so you can accidentially write over what has been written to automation.
If it's a mix question, best ask in the mixing techniques forum.
Either the OP is totally misusing some terminology or I'm bat shit crazy. One of the two, maybe both.
Easiest way to set the locators is to select all of the audio events you want to repeat and hit "p" on your keyboard. Enable loop and viola done.
A REALLY quick way of selecting everything to loop is apple/command+A then hit P. Done.
