A
adessmith
Hi everyone,
I am trying to troubleshoot an old WR-T820.
It appears that this is a pretty good console used in a lot of studios in the 80's, and you guys seem to be very knowledgable with high end studio consoles.
It worked fine untill it was moved. It was stored on its side, in a corner, for over a year, and now we cant get it to work.
If there is anyone here that knows a little about these consoles can you give me your thoughts on this issue?
I cant seem to get anything but a VERY low output signal from any of the inputs. I have tried routing to subgroup outs, and to the main L/R outputs, and I have to CRANK the gain wide open to get a barely audiable signal.
I can PFL the input and I get good signal to the meter, so I believe the signal is getting to the preamps ok.
Are the green lights next to the on buttons "on indicators", or are they "signal indictors"? I figure they are signal indicators because they dont come on when I "un-mute" the input.
Here is the strange thing, I can push the gain up wide open, to where it maxes out the meter when I PFL it, but I dont get any signal indicaton or clip indication on the green or red lights near the fader. Shouldnt the green light be flickering? Also, nothing lights up on the meter bridge.
How is it that, on every channel, the signal gets lost somewhere between the preamp and the fader?
This seems like there should be a logical expliantion...
I dont know a lot about repair on consoles, is there anything internally that could be loose that would effect all the channels in this way?
Would I be correct in my assesment that the signal is getting lost between the preamp and the channel fader?
