Total # Of Inputs
20 - Total Inputs
Mic/Line Inputs
Line: 12 - Balanced 1/4" TRS Phone
Mic: 12 - Balanced XLR
Stereo Line Inputs
Ch. 13-16: 4 - stereo paired (8 mono) Balanced 1/4" TRS Phone
In-Line Inputs/Returns
No
AUX Sends
2 - Aux Sends: 1/4" TRS Phone
AUX Returns
Aux send outputs are returnable via input channels
Inserts
Ch. 1-12: 1/4" TRS Phone
Mix Insert: 1/4" TRS Phone single jack
BUS (Group) Outputs
Mix + Sub outputs: 2 - stereo paired (L/R) 1/4" TRS Phone
Main Outputs
Mix: stereo paired (L/R) balanced 1/4" TRS Phone
Mono Sum: single balanced 1/4" TRS Phone
ALT I/O
Stereo Paired (L/R) 2 Track output via RCA jacks
2 - stereo paired (L/R) inputs via RCA jacks channels 13-14 and 17-18
Monitor Outputs
Monitor: stereo paired (L/R) balanced 1/4" TRS Phone
Direct Outputs: balanced 1/4" TRS Phone (ch. 1-12)
EQ Section
3 - Band EQ on all mono channels - High, Mid and Low Frequency
2 - Band EQ on all mono channels - High, and Low Frequency
Solo/Mute
On and PFL switches on every channel
Channel Level Control
100mm faders
Trim/Gain Control
Sens: 0 to -60dBu ch. 1-12
Level: 0 to 22dB ch. 13-16
Phantom Power
+48V Phantom Power (global switched)
Metering
10 - segment stereo peak LED's
Frequency Response
Mic/Line in to any output
25Hz to 30kHz < 1dB
Dynamic Range
not specified by manufacturer
Signal-to-Noise Ratio
Measured RMS, 20Hz to 20kHz Bandwidth
Line inputs selected at unity gain and terminated 150R
Total Harmonic Distortion (THD)
Mic Sens. -30dBu, +20dBu at all outputs @ 1kHz < 0.006%
Power Supply
details not specified by manufacturer
Dimensions
18.86 x 3.15 x 20.14" (479 x 80.0 x 511.5mm) (W x H x D)
