Psycho Clown
Hi everyone.
I just joined the forum to see if anyone can point me in the right direction to get this slight problem sorted with my Fostex R8.
It's been boxed up and unused for about 8 years (since space in my house became an issue).
So this week I took a trip down memory lane and got it out along with the Studiomaster mixing desk (it's all set up in my living room and although fun, not practical) and loaded one of my old tape reels.
To cut a long story short, it strained as it played and it wouldn't rewind, so I took it apart to discover that the supply reel (left hand side reel) belt and the plastic wheel on the motor spindle had come off. Easy enough to put back on I did that and put it all back together again. It played fine, FF fine but again when I started to rewind, the same problem.
I took it apart again and put it back on and with the front off and the machine in a horizontal position, I ran some tests to see if I could determine what was causing the wheel to come off it's spindle (at the motor end).
It seems to rewind fine, but when you hit the 'Stop' button, the belt seems to go out of line on the reel table wheel and pull the plastic wheel off the motor spindle.
I hope I'm explaining this clearly enough... I can take pictures if anyone needs them.
Any ideas?
I shouldn't need to adjust the reel table wheel, but could it be the tension of the belt that needs adjusting due to it being sat all that time?
I did download an R8 service manual off the internet earlier today and have looked through it, but there's no mention of this specific problem.
Any ideas?
