FattMusiek New member Jun 11, 2006 #1 Is the Firepod compatible with Pro Tools software? If not, is there a patch that makes them compatible? Thanks for your time.
S sixways New member Jun 11, 2006 #3 You could use the pre's from the Firepod if you had a Digi 002 or M-Audio Delta 1010. Otherwise, no. 6
TuoKaerf New member Jun 11, 2006 #4 I suggest you read this . To run Pro Tools, you have to have an appropriate Digidesign hardware unit.
