Questions about Echo Mia ???
  • Thread starter Thread starter mace
M
mace
I purchased and installed Mia a couple
of days ago. I have two balanced XLR to TRS
cables (one side XLR, other 1/4 TRS). I'd like
to know if it's ok to plug Mia to my Spirit
Folio Notepad's XLR Mic inputs. Or do I need
XLR to TRS adapter to plug it in Line inputs?
I have SW1000XG and I want to use through
Mia's digital input and then If SW1000 is
syncmaster in 44,1 KHz rate. Can't I use
use 24/96 recorfding in Sonar?
info
IF YOU WANT TO GO OUT OF THE MIA INTO THE MIXER THAN YOU MUST GO INTO THE LINE INPUTS. IR THE RESULT MAY NOT BE PLEASANT. AND I WOULD SUGGEST A TRS-TRS CABLE, TO AVOID USING ADAPTERS.
AND WITH 2 DIGITAL DEVICES YOU CANT HAVE THEM IN SYNC AND AT DIFFERENT SAMPLE RATE AND BIT RESOLUTION. BECAUSE THERE IS ONLY ONE CLOCK, OR MASTER. THERE IS NO WAY TO THROW A SECOND SAMPLE RATE INTO THE EQUATION.
Re: info
Caps button broken?
