Question
  • Thread starter Thread starter scottfisher
scottfisher
Hey, I have a question. Im thinking of buying a Tascam US 122, and I want to use a MIDI keyboard with it so I can use the sound effects in my recording. Would this cheap Radio shack keyboard work? What is it missing?
Keyboard
It would indeed work. (Though you'll need MIDI cables)
It's more over, what exactly do you intend to do with it?
You will most certainly be missing, pitch and mod wheels and aftertouch.
You may be missing velocity sensitivity.
Other than that, any keyboard with a MIDI out will work to some extent. Especially for step recording.
Carl
The biggest thing you'll be missing are full-sized keys. Mini-keys will make it vitually useless for any real playing and will probably mess up your technique if you use it extensively.
Ted
I just want to use it in ACID to control the sounds, because without a MIDI device, I cant (I dont think).
Like so I could make that sound on the piano (the note) sound like a choir, or orchestra. I dont know what to call it. Maybe as a sampler? Dont know!
As Krakit and Tedluk indicated, yes, this keyboard will do the job, but it is is lacking in several features that you may later find important. Also, I don't think you'll be enamoured with the sounds. You may not care if you want it solely to control soft synths, but if you are interested in the sounds it generates, then $50 ain't gonna get you much :)
Hope this helps.
Thanks. One more thing...
Is there a cheaper keyboard to use for soft synths?
You may want a controller keyboard. Do a search on this forum for controlllers. They do not make any sounds themselves - they just generate midi data to send to the soft synth.
scottfisher said:
Would an Evolution Ekeys 37 be better?
Better than what?
It will do the job. I don't particularily know this keyboard, and USB controllers are unknown beasts to me. I'm an old-fashioned midi-cable/midi ports type of guy.
How does that connect to my computer?
Through a usb cable.
Thanks for all your help, I'll get one later on, when I need an orchestra, or some piano. :)
Thanks again.
