question regarding behringer mx1604
  • Thread starter Thread starter bluesboy87
B
bluesboy87
hey, first off im sorry if this is in the wrong forum, if it is please point me to the right one.
I've been lookin at the mx1604 for recording to a stand alone 8 track machine.
Im pretty sure i under stand how to record with it, but what about mixing down, since the recorder probly will have 8 outputs, will i need another mixer, or can i use this one. I've been looking at the inputs and the controls and it dosent look like I can. if i can will you please explain how.
this may look like a stupid question, but hey, there was plobly a time when you didnt know stuff like this. right?
and besides it is in the newbie forum.
thanks.
The MX-1604 won't be a good choice because you only have 2 stereo subgroups and no individual channel outputs.
i use the mx2004 with my eight track, so i can record up to 8 tracks at a time using the channel inserts (this is explained int the manual).. then to play back i just unplug the mics and plug in the recorder..
the 1604 will limit you to only 4 mic pres (so 4 mics at a time) and you will only have four channels of eq with a sweepable mid... the other four are fixed e.q.s.... finally the 1604 won't leave you any strips for aditional routing
so i think a few extra dollars will go a long way here
either the MX 2004 as explained above, or the UB1622FX Pro will work. The UB1622 has inserts in the mic channels, so you can get 4 direct outs there, 2 more from the main outs (L R), 2 from the sub groups, and another 1 from teh Aux 1 if set to "pre"....and the UB series has better mic preamps than the MX series.
The UB1832 is even better with 6 channels with mic pres and inserts for direct out, and another 4 stereo channels, plus 2 outs from mains and 2 from the subgroups. This also leaves channels open to monitor the return signals.
