Question for DarthFaders
  • Thread starter Thread starter MartyMcFly
M
MartyMcFly
I was wondering what effects u use on your vocals. Do you use any of the compressors that you get with your effects thingy on the VS? What type of reverb/echo? More specificly what are the settings? Run me through a typical set up.
I record vocals with a GrooveTube AM52 mic, through an Aphex 107 mic pre. Once in the my VS2480, I do a track export, and take the wav files into the computer. There, I use the Waves RCL compressor, and the Waves DeEsser. I usually compress pretty massively. I use the Waves vocal preset for the compression, and sometimes take the threshold down to as much as -40 dB. There really is no way to just write the settings down, because they will be different for every vocalist.
I also silence any part where the singer isn't singing, to take out room noise, etc.
After this, I bring the tracks back into the 2480, and usually compress again, infinity to 1, and the threshold depends. I then use a high pass filter to roll off everything below about 80-100Hz. I do any other EQ adjustments needed, which usually for me is adding a bit of high end: 1-3 dB shelving from 2, 3, or 4 KHz and up.
Then mix them in!
Hope this helps at all....
Darth
Man, you is a round about going fool. I can't argue with yo results tho. Yu keep up the good wrk.
Just a follow up...I have a few more questions...
Don't laugh...
What is Waves RCL and Waves de-esser?
Are they computer programs? And where can I get them?
Waves is a company that makes plugins for audio programs. The RCL is one of their compressors, and the DeEsser is their DeEsser. A DeEsser is like a frequency specific compressor, that helps to get out the `S' sound, if it's too loud.
Check out http://www.waves.com/ for more information on Waves products...
Darth
Or buy the license to use them, but install the cracked versions instead. They work flawlessly... believe me... :o
Ultrafunk
I second the opinion on Ultrafunk stuff.
Sound great and easy on the CPU too!
