C
concubine
So, when recording digitally, I use a Yamaha 01v with cubase, via the ADAT i/o connection with a Wavecenter/PCI. This set-up has worked well, as I can record at least 8 separate tracks simultaneously into Cubase, not to mention the 01v makes for a nice control surface.
However, I've been wanting to use outboard pres, and I've been wondering if there is a way to bypass the pres in the 01v, or if merely turning down the gain and padding the channels on the 01v is enough. My concern is that doing the latter would still give me a bit of that 01v pre sound, which isn't always what I want.
I've heard that the pres in the 01v can't be bypassed, so can anyone here back that up? Also, if this is true, could someone recommend a different console where I could do the same thing, but which allows me to bypass its pres? Or should I just use an analog board and use something else after it in the chain for the analog/digital conversion?
I appreciate any comments/suggestions!
