Fims
When producing (and mixing) what volume is best to keep it under.
I read sonusman's mixing techniques and he says this
"I would recommend that you record a 1KHz test tone on your system, and play back that test tone through the same D/A converters you will use to monitor your mixes. With the test tone recorded at -6db digital full scale, use a dB meter and turn up your monitors until that test tone is at about 85db with a C weight on the meter. I am not kidding"
Can anyone put this in easier terms to understand? As Im completely oblivious to mixing instrumentals and such.
I have a stereo connected to my PC (no monitors till january) that goes from -85db - 0
and I use Ableton as a DAW. So how would I determine at which volumes to mix... Thank you!
Just need a simpler explanation.
ALSO. How loud should the mixdown be before the master?
