When you use say you use compression...
Do you mean that you use compression when going in to the interface? I mean, I definately use it when mixing. Either with plugs or outboard. You see I just got a Motu interface and I am trying to get used to it. It seems easy to overload. In the past I have used a pre with compression lightly on every single thing I tracked and that keeped things from overloading the old interface that I used to have. Now I have some better pres and I don't really have much as far as outboard compression that is any better than the waves and sonitus stuff that I have. What I am wondering basically, is do other people not have trouble with singers overloading the interface. I am recording in 24 bits and all. The Motu only records at 24 bit. I am using Cubase SX 2. The singers I have worked with and myself, know how to work the mic, but it is seems a bit like there must be a better way to track. Is this common to track without a compressor on a strong vocalist, or should I grab an RNC. Would that be a wise investment to throw in the chain. Would that help control the output of what comes from the outboard pre before it hits the interface. I don't want the compressor to mess up the good thing going with the sound of the mic and the pre. Sounds fabulous, I don't want to ruin the crispness, but I would like to smooth out the levels a bit before further processing in the box.
