W
Wilde
Member
If you're getting the sound you want, then do it. If you think you could improved the sound, try it differently. Most people do not want to apply EQ or any FX to an incoming signal - because then you are stuck with that sound in your recorded track.
And a MOD needs to move this out of the "studio building" section of the forum!
Rule 1: If it is delivering the sort of sound you are happy with, stick with it.
Rule 2: Keep input paths as short and as uncomplicated as possible. This sometimes conflicts with rule 1.
For a long time I used a mixer to feed into an interface. I also had a number of outboard effects..
Over time, I've gradually shed these. I now go straight into the interface and do everything in the box.
I like being able to try things then change my mind.
What software are you using on the computer - most decent software will give you eq and effects nowadays, so using the mixer for this seems a bit pointless. I have some rather nice mixers in use with my systems, but they sit with their faders in a row and eq switched out - just allowing me to get a pile of external sound sources into my interface - once it's in the machine, I do everything there - far simpler and sonically better.
Going from device to device is very common in stage sound - cascading mixers isn;t really an issue with most kit now - in your case, it obviously works and you are happy - so that is fine. You can just do more inside a computer nowadays - with eq, fx and mix automation.
I don't use the mixer as my main source for EQ - I just thought that instead of recording my voice flat I would use the Higs, Mids and Lows of the mixer
