Question about SFZ and soundfonts
  • Thread starter Thread starter jmasek
J
jmasek
Member
Hope this is the right forum for this... I am new with MIDI and trying to understand the intricacies.
I am using SFZ as a MIDI virtual instrument to play soundfonts. Some SF2 files have multiple instruments included (e.g. bright trumpet, dark trumpet trill, etc). Is there a way to include multiple instruments in a single MIDI track (and how do I specify this on the piano roll)? Or do I need separate tracks for the regular trumpet and the trills? I am using N-track studio v4 if that helps...
- JM
I'm not familiar with the software you use, but most MIDI sequencers let you send bank and patch changes right from the track. So if you have a least a small part of a second between the sustained notes and trillls, you could insert a patch change command to switch to the trills, play the trills, then go back. That's probably what I'd do in that case.
--Ethan
