M
mikehoman316
Hi there, I'm a first time poster and relative noob with a question about levels.
I've been reading a book that recommends your peak levels for recording audio should be around -12 to -6db
Does this also hold true for the main output channel?
Usually when I've finished a mix with the main output at around this volume the bounce comes out extremely quite compared to other pro-recorded music.
Is this volume discrepancy normal? Is it a problem that should be rectified in the mastering stage or is it common practice to simply bump up the master volume so it peaks at greater than -6db?
I hope I'm making sense. Any advice would be appreciated. I'm using Logic Express 9 btw.
