Question about my DP03 EQ
  • Thread starter Thread starter xzyphyr
X
xzyphyr
According to the manual I should be able to set the EQ separately for each track to mixdown, I can access Input A and B, and I can set track 1..... I can find no way to change it to Track 2 so I can set the EQ on that track, I imagine if someone can walk me through getting to track 2, the other tracks will be easy.
In the manual, Page 24, item 17 ... Rec buttons/indicators ... "Press these buttons when the TRACK EQ screen is open to select tracks" ... whichever rec indicator is lit is the channel to which you are applying EQ. While the EQ screen is up, just press the button on another channel to EQ that channel.
Thank you RustyAxe, it's all so easy when you know which button to push. I think the manual should have listed that info under an EQ heading, instead of REC buttons / indicators.... Thanks again!
