X
Xpred
I was just wondering simply the "correct" way of turning things on or off without inviting dangerous hazards. I was told for FireWire interfaces, not to hotplug. So what I do is have the computer off and the interface off, then plug the firewire into the computer. Then depending on if the interface has an on/off switch, I turn on the interface (if it has the switch), then turn on the computer. If not, I just turn on the computer, and it then powers on the interface as it also turns on. However, I still am confused on something... like for instance the way to turn it off? I use an interface where it has no on/off button, so I always just turn off the computer, and then the interface turns off by itself (no bus adapter). I suppose this is the only way to do it?
If you have an interface that has a power switch, I guess you should still turn the computer off, then press the power off on the interface?
Also, what about the mics.... is it best not to plug/unplug mics if you have the phantom power on?
Last question, what happens if your computer crashes or restarts abruptly while powering the interface? Would there be a chance that it would shortcircuit or damage the interface hardware?
Thanks.
Thanks.
