Question about Behringer UCA222 and v-amp 3
  • Thread starter Thread starter Sub7
Sub7
SOLVED: Question about Behringer UCA222 and v-amp 3
Hello dudes :rolleyes:
i got a problem which i cannot solve by myself
I am a guitar player and since today i always used a V-amp 2 for pratice and little recording using regoular Line in. (cable connected FROM v-amp line out TO my computer line in) and i use a cakewalk usb to midi cable to change the v-amp presets using v-amp design software.
Well today i got as gift the new v-amp 3 and in his package i also found an uca222 usb audio interface which i dont know how make it works.
I have installed the drivers and i can see it on hardware devices succesfully installed and working but when i plug my guitar it doesnt emit any sound.
The connection i've maded is like that:
1) UCA222 is conneted via usb in my computer
2) UCA222 is also connected in the AUX IN of the new v-amp3 and the 2 rca are plugged in the RCA OUT jacks in the uca 222 (i also tried plug them on input)
3) Active speakers are directly connected to my pc sound card so no to a mixer which i dont have.
I attached an image for better understanding:
In audio control panel i see BHERINGER UCA222 i maded a screenshot:
Well i dont know whats wrong, i dont even know if this UCA222 device can replace the normal LINE IN as i need or not. I just want my guitar play like i have line in plugged but using the uca22.
Sorry for bad english i hope somebody understand! :D
I use WINDOWS 7 s.o and i have a crappy realtek integrated sound card.
I tried to change audio settings in various way but without success, if i plug the uca222 into the line out of v-amp it works but have no sense and delay is crazy.
okay the first thing is that if you plug in the uca222, then it should bypass your intregated sound card. so uca222 is now your sound card and you should connect the speakers to uca222 output. HOWEVER since the uca output is already taken by v-amp then use Line out R & L to connect your speakers.
Hello thanks for answer me,
So i have totally disable the integrated sound card of my pc from the bios and connected my active monitors directly in the uca222, unfortunately isnt working dunno what i am doing :confused: :( i have behringer ms20 active speakers. I noticed tha now if i go in audio control panel and play some mp3 that the "graphic equalizer" is in "movement" but no sound. Picture:
Sorry i dont get it when you say:
HOWEVER since the uca output is already taken by v-amp then use Line out R & L to connect your speakers. ?^?????
EDIT:
now the speakers works, i have connected the outputs to the speakers but the line in doesnt works. it's activated but mute.
picture:
Looks like i solved, uca has to be connected to the PHONES OUTPUT of the v-amp and not into the aux in. Imo all this is kinda weird.
thanks for help :)
