M
merlinguy
I am pretty sure I saw this info somewhere, but can't seem to retrace my steps. Is Quantegy 407 susceptible to sticky shed?
I will likely have lots more dumb questions.
Thanks for the welcome; The tape is on 10.5" reels but I'm going to pass. Recorded some Patricia Barber last night on a new SM911. I see no reason to take a chance on old tape.
Quantegy 406/407 is good stuff. You can't go wrong with it. 407 is one of my preferred tapes for mixdown. Its character is more similar to SM911 than 456. It has a softer quality to it when hit with hot levels. I use 407 (among other tapes) because I have a Tascam 22-2, which requires 1 mil tape. Quantegy 406 would be good for the BR-20 as well and would have a bit less print through since it’s 1.5 mil. If you find a good deal on unopened Quantegy branded 406 or 407 you should snatch it up.
While the 22-2 performs slightly better with 1 mil tape, it doesn't require it. Fact is, you would be hard pressed to hear any difference when comparing 406 to 407, 456 to 457, or any 1.5 mil to 1 mil tapes of the same oxide formulation.
Tascam’s guidelines (requirements) regarding tape are pretty straightforward:
The use of tapes other than those we recommend for the 22-2 will produce results that may lie outside the limits of our published specifications. The use of 1.5-mil tape is not recommended.
-Tascam 22-2 Manual, Page 2
I doubt that there is a warning about excessive wear, stress, or voided warranty if 1.5 mil tape was habitually used.
Well Rick, excessive wear and stress is exactly what the guidelines are about. Me being the curious fellow that I am, a simple "Don't do This" was never good enough for me. The points (except for #2) in my previous post are from Tascam when I asked why 1.5-mil tape isn't recommended for certain machines. It made perfect sense when it was explained to me many years ago. My point #2 is simply common sense based on the age of the machines we're working with.
Tascam is no longer concerned with warranty or lawsuits over specs (if they ever were) for these vintage machines, yet the recommendations still stand.
I was involved with TEAC/TASCAM in the late 70's to the early 80's as the beta-tester for prototype & early production pieces. The personnel I had contact with during that time which included the company founder, design engineers, and marketing folk, were my sources of information. That being said, we will probably never agree on this particular subject.
The bottom line is this... The 22-2 was probably the least expensive half-track ever made. It was based on a consumer model TEAC X-3. It's delicate but very capable if best practices are followed. Very simply, it takes less reel tension to achieve optimal tape-to-head contact with 1-mil tape. This was a fundamental design consideration when the 22-2 was conceived. But the physics behind tape thickness/stiffness and wear are universal and were around long before the 22-2.
I've ... known many ...folks... some understand the nuts and bolts ... and some don't.
