Qaulity reel to reel tapes
  • Thread starter Thread starter kip4
kip4
kip4
I'm certain this will have been asked many times before but here goes
What's a good qaulity reel to reel tape (1/4") Which brands should I buy?
Which brands shouldnt i buy?
I'm located in the UK
please feel free to post a link.
Also i really like the look of those metal spools are they hard to find and expensive please?
Using the search feature will find you lots of good info so please definitely do that, but there are two companies manufacturing new tape currently: ATR Magnetics and RMGI.
ATR makes one formula which you can calibrate to pretty much whatever you want up to +10; some hit it at +6 though I like +9 and think print through can be an issue above that especially if you aren't being pretty conservative with your levels. I've used the ATR 1" for indie rock and acoustic folk projects; it sounds very good and the reels I've tried seem better slit than the 2000's-era Quantegy tapes I've used, but there are a couple caveats: 1) you have to run it back and forth a couple times and let the excess oxide run off, keeping your tape path clean as you do it, and 2) they let a bad batch get out in autumn of '10; avoid any ATR tape from that time and you should be ok. ATR's customer service is great.
RMGI does modern versions of former EMTEC formulas--SM900 (+9 tape), SM468, SM911 and its variant LP35 (+6 tapes). I haven't used them yet, but others here have discussed them so do a search. As with the ATR, buy fresh reels and you should be ok.
Take a look at the Sticky Shed thread at the top of this forum for info on what to avoid; probably at the top of the list of tape not to buy is Ampex 456, though Quantegy-branded 456 should be ok, as should any 499 or GP9--but those Quantegy tapes are about 8 years out of production so you'd be getting them new-old-stock or used. On a side note, I question the slitting of 2000's-era 499 and GP9, I've found I have to wind fresh NOS reels of them back and forth a couple times to let them "shave off" a little on my MCI machine, though this may not be such an issues on other machines, I dunno.
This weekend I will be recording the same folk band to some new-old-stock GP9 that I did to ATR this spring, so will be able to draw more comparisons between the two.
Studiospares: Home at Studiospares
...they sell RMGI tape, specifically the SM911 and SM900 variants. SM911 is good for multitracks and mastering decks, and is a direct replacement for Ampex/Quantegy 456.
SM900 is higher end stuff and is roughly equivalent to Ampex 499. Not all decks can handle it.
Carousel: Open Reel Carouselmedia.com
...these guys sell LPR35 which IIRC is a better bet for consumer level decks like the Akai 4000. I haven't bought from them myself.
Then we have Stanleys: Stanley Productions : Audio
...they're the UK's exclusive supplier of ATR tape. People say it's good stuff (though it's most suitable for pro machines rather than TASCAM etc), but the prices are quite remarkable and not in a good way.
Oh, and I almost forgot Canford: ZONAL AUDIO RECORDING TAPE
...they stock Zonal tape, which is only available in 1/4" format. 700 is equivalent to Ampex 456, I think 675 is equivalent to BASF SM468, 820 is equivalent to Ampex 406, and I believe 840 is a long-playing version of 820.
For a consumer deck you'd probably want 820 or 840. For a professional or semi-pro mastering deck, 700 would be a better bet, I think.
NOS is this new old stock?
Btw BrianK love the location Oshkosh. is that for real?
I forgot to mention that the 10" Zonal stuff sold by Canford is on a hub - you would need to spool it onto an empty reel before use. However, I believe the 5" and 7" tapes do come on a plastic spool.
And yes, NOS stands for New Old Stock.
I've negotiated a deal on a box of old tapes from someone i know who just wants rid.
I've also just finished reading the sticky shed thread. It took a while to read it.
I think i'm going to have to be carefull and keep refering back to the thread to sort out the good from the bad.
If i get a few good tapes i will be up on the deal so i think theres a fair chance i'll be ok.
I'm hoping there will be a test tape included. I didnt even know such a thing existed till i read the sticky shed thread.
Plus i found out my guy who repairs my gear is a R2R freak to and he loves repairing them.
Bonza!!!!!!!!! I'm learning
I have no idea yet mate
I think some will be prerecorded some blank recordable.
The guy just said his son had a massive box of tapes and he wants rid.
I think he must have lost his son because he's selling all his audio gear.
