L
Lostinspice
Long time lurker, first post (and it's a weird one).
I have a bunch of songs programmed into an old Kawai Q80 hardware sequencer. I wanted to transfer the midi songs into Sonar, so I set Sonar as the slave and armed its midi tracks to record. I set the tempos the same in each machine. I pressed the Sonar record button, then play on the Q80. The midi info got dumped into Sonar, but as I monitored (through the VSC DXi) I could hear it was not only slower, but in a different key! After stopping and playing Sonar back, the midi info was indeed lower and at a slower tempo (not the tempo shown onscreen).
I can play the VSC in Sonar with the Q80 just fine. It only acts up when I try to record. By the way, the Q80 transmits MMC. Although the Q80 has a floppy drive, I can't transfer to the computer this way because it uses a format Sonar won't recognize (not Standard Midi File).
Anybody have a suggestion? You guys seem to know Sonar inside out. Thanks in advance for any ideas.
