Prsonus Firepod preamps don't turn off
  • Thread starter Thread starter Rich Haigh
R
Rich Haigh
When using my Firepod, I noticed that the preamp gains do not completely turn off when turning the knob all the way counter clockwise. For example, if I have a guitar plugged into channel 1, I can increase the gain by turning the knob clockwise but when I turn the knob completely counter clockwise, I can still hear the guitar (lower volume but I can still hear it and it shows coming though on the graphic levels in Sonar). I thought that if a channels gain was turned to 0, then no signal would go through. Is this normal or is something wrong?
Thanks,
Rich
I don't think I've ever owned a preamp where minimum gain killed the signal.
It sounds fine.
From the Firepod manual, I see this:
Microphone Input XLR: 45dB of variable gain (+14 dB to +55dB)
Instrument HiZ Input TS ¼” (channels 1 and 2 only): 45 dB variable gain (+8dB to +50dB)
This means, the even on minimum setting, the Instrument input is getting 8dB of gain.
So, the device seems to be working correctly.
Paul
