Proper use of 2 hard drives with Cubase
  • Thread starter Thread starter choctaw
choctaw
choctaw
Tribal Member
I have added an extra HD to my system. Which means I can put all the audio files created in Cubase in one place away from any other software. Is that helpful by letting one HD contain my music files, not requiring the computer to skip around looking for all the lose ends. And what about the Cubase software where should it me..........on the same drive as Win XP is where I have it, along with my Tascam 428 controler software. I plan on using a seperate drive for my musice files...........any coments appreciated.
Choctaw
I recently posted a similar question. The answer that I got was to keep all of the programs etc. on the boot drive (the one with the OS on it) and use the second drive for files. That way, all editing and other resource-heavy tasks will be performed on the second drive, which you can keep clean and free of fragmentation and have a good environment for the programs to manipulate the files in. And as you said, you will have a seperate place to keep track of your music and other related files, and not lose stuff in the midst of your boot drive. You do not install any programs on the second drive, it's for files and cache folders etc. only. .
Many programs have cache folders etc. that go to a spot on your boot drive by default, but can be changed and reassigned. In that case, you should also move the cache folder(s) over to the second drive, where you can make them as large as you want (only limited by the size of the drive) and they will stay clean and free of the junk that can end up there when they are on the boot drive. However, you still don't want to make the cache folders overly large, that would be a waste and lead to fragmentation - check the documentation of the programs to determine the optimal cache folder sizes.
In my case, I purchased the fastest HDD (within reason) that I could get and made it my designated drive for music files, as well as for graphics files. There is plenty of room for both. I bought a WD Raptor 10,000 rpm SATA drive, it is expensive for a 74GB drive, but to me it is worth it. 74GB of dedicated space for files is still way more than enough, even with the graphics files, since there are no programs or anything else on there. I had considered putting a really big drive there - I could have purchased a 300GB 7,200 rpm drive for about the same price, or less, than my Raptor; but in the end I wanted the performance and really had no need for a drive as large as 300GB.
I'm trying to understand the way in which my software stores music files.
I use Guitar Tracks Pro2, and I can only guess that it follows similar sytems to other software programs. It sets up these default folders for you:
Audio Data
Drum Styles
Parts
Picture Cache
I then set up the following folders where I save my projects:
Projects.....................where I save the GTP2 'project' in GTP2 form
WavelabProjects..........where mixed down projects go
WavelabRendered.........where final mastered projects go, ready to be burnt to CD
I think the "Audio Data" folder holds all of the individual tracks that you record. My Audio Data folder is about 5 gig at the moment. The contents is all wav files. "Drum Styles" seems to be a folder to store your loops in. I have some default sample ones in there, but I don't really use loops/ drums at this stage. I am not sure what the "Parts" folder is for. It has about 50mb of files in it. They are a combo of wav and GTP2 files. I am not too sure what the go is with that folder. Then there is the "Picture Cache" folder, which seems to hold WOV files. I think these are 'images' of wave forms so that GTP2 can load them up nice and quick when you load a project.
So, that's what I understand about folders for my software. I know some things, and some things I don't know. All these folders exist on a slave SATA 7200 80gig HD.
dual drives for extra storage and smootheness
Springo said:
I recently posted a similar .................
Thanks Springo.......for your info. Your drive is faster than the Seagate 160-7200 Firewire I am using, but I like the extra place to put music and tweak it.
Chocatw
...You can even install a 3rd drive for sample streaming...if that's your thing.
