Problems with loading audio/recording into Sonar
  • Thread starter Thread starter joewolensky
J
joewolensky
For some reason all of sudden whenever I try to load an audio file or record into sonar, it freezes and shuts off. I have no idea what has happened. The last thing I did with it was take it to a church to do some mobile recording and now it wont work. We did change the input to +4 ,but I have switched it back to -10. Other than that, thats the only thing I changed.
this is a long shot but I'd take the side/top/back panel off and make sure that non of the cards have come loose or popped out
I doubt it has anything to do with input levels. It sounds to me like you've got some software issues or driver problems problems. Have you made sure nothing else is running in the background? Make sure you have the most up to date drivers for your sound card/audio interface. Try switching the from WDM to ASIO or vice versa to see if that is the problem. You might also want to check with Cakewalk support and see if they can help you out.
Thomas
www.yourhomestudio.com
Free Home Studio Newsletter - signmeupnow@yourhomestudio.com
