problems regarding crackling and loss of signal
  • Thread starter Thread starter Melsi
M
Melsi
Padawan
ok, so sometimes when i record i get a loss of signal and some crackling, (im using a SE Electronics Z5600a mic going into a focusrite platinum voicemaster pro into my ESI Waveterminal soundcard breakout box then into my pc)
and when i click the phase reverse switch the crackling will dissapear and the signal will come back, but even with the phase reverse switch on this still sometimes occurs, does this mean my pre amp is faulty?
this never happened when i had a condenser mic running into my pre!
and the strangest thing is, when i have process bypass swithced on, on my pre everything is fine,
and i only use the optical expander and compressor on the pre!
I had a similar situation. I found out the cause for me was my Art Tube pre. I switched to the pres on my analog mixer and the problem disappeared. There was also an improvement in sound.
but the pre's on my mixer are absolute rubbish and the focusrite pre's are normally very good
