K
KevinTran
I've got my wireless SM58 hooked up via XLR to my mixer. Got the mixer hooked up to the sound card from "Tape Out" (R/L) to LINE IN (with Y-connector). Phantom power tried ON and OFF.
1. Why would the volume be so low when recording (both voice and music) from the mixer.
2. Do you lose stereo going from the mixer to a single input line into the sound card?
3. Do the thin 1/8" connector wires degrade the quality and volume of the sound it is transporting from mixer to sound card?
One article says <<... the easiest way to use a mic channel for feeding a soundcard is to turn its fader fully down and then use the pre-fade send control to send the mic signal to the mixer's pre-fade output jack. This is normally used to set up monitor mixes, but in the smaller studio it can be fed directly into the soundcard input as a means of routing the mic signal separately. Essentially, the mic signal goes through the mixer channel, via the pre-fade send and out of the pre-fade send jack without interacting with anything else the mixer may be doing, almost as though it were going through a separate piece of hardware. >>
Is he referring to the PFL on my mixer (assuming prefade line)? No manual, gotta guess at alot of this stuff. Then my PFL Out line is a 1/4" output.
Is there a cable made that goes 1/4" out and 1/8" in?
