T
TentilEight
I am using a 24bit wav file that I recorded with Cakewalk ProAudio8 and saved and edited in CoolEdit pro as a 24bit wav file (using options for save from cooledit pro. The problem is I cannot load the file into Cakewalk by inserting it as a wav file. The system just hangs and won't deliver. I set up cakewalk to handle 24bit files but it doesn't appear to be working. I have full versions of both products (no lite versions, anymore). When I convert the sample type to 16bit with cooledit, cakewalk will load it then. Has anyone experienced and solved this problem before?
