A
Agent47
Dismember
Hi there. I'm starting to use Pro Tools (6.2.3) more on a daily basis, and was wondering if there were any experts here with some answers...
Yes, I know, 'RTFM', but I find it really hard to find what I'm looking for in it...I guess this might be quicker...
1. I've got two mono tracks. I want to go into the mixer and turn the two mono faders into one stereo fader for easier automation. How do I do this?
2. I've got some music in stereo on two mono tracks. I see that trimming both tracks simultaneously is done by highlighting both L and R segments then holding shift and trimming. How come fade doesn't work in the same manner? How do I fade two monos simultaneously? Currently, holding shift just fades one of them, not both.
3. Can you view/edit automation 'rubber-band' style? If so, how?
4. Say I want to make a cut/snip (separate) across multiple tracks, how do I select across them without it asking me to 'name the region'? I find if you're just one micron to the left or right, it thinks you are creating a region. I know that if you click on the timeline at the top it selects the whole lot - but what if I just want to separate two tracks but not cut through everything else?
5. Is there any way of creating groups of audio without consolidating? For example, say I'm doing a radio ad which has 10 different tag lines at the end, I want to copy VOs on tracks 1 and 2, effects on tracks 3,4,5,6, and music on tracks 7 and 8, and create a single group (that behaves as a single segment) which is then used as the master for copy/pasting - rather than pasting a collection of separate segments. I need to be able to open up the group after pasting, in case any segments need to be moved for time constraints, so I don't want a consolidated segment.
Yeah I know, RTFM...
Thanks,
A47.
Thanks,
A47.
