T
Treva
Let me explain my problem(again) with a better explanation.
I'm using win xp service pack 2 with pro tools 6.4 and digi 001.
There's no problem with digi 001 cause this problem only happens on an especific situation.
Here's the problem =
When I open a session of my old pro tools 5.1 in pro tools 6.4, after recorded a few new tracks it starts to record other new tracks out of sync.
It records some miliseconds after what I played.
Here's what I tried =
1- Started a new session and imported all 5.1 tracks = the same problem.
2- Bounced my 5.1 tracks and imported to a new session in 6.4 = the same problem.
3- Uninstalled pro tools and installed again = the same problem.
4- Formated my hd and installed everything from the scratch = the same problem.
What I realized =
It only happens when I try to use my old 5.1 tracks with new 6.4 tracks..
No digi problem cause with sound forge and acidpro it's working perfectly, the problem only occurs when I try to use my old tracks with new tracks.
So do you guys have any idea or saw that already with any other daw?
Any advice,tip whatever?
Maybe I need to convert my old session/tracks to something and then use them with 6.4?
I googled about it but no answer.
Thanks
What I realized =
Thanks
