D
daniel101
Using pro tools 7.4 before and this problem never happened but just got pro tools 9 and whenever i arm the tracks in pro tools 9 and turn the mix knob to the right on my fast track pro i get choppy and cracking audio . I have did all the computer optimazations, tried new cords and changed the buffer sizes in pro tools but nothing is working, I have also installed all the drivers anf new updates for pt 9 and fast track pro
I am using new pro tools 9 on windows 7,fast track pro connected through usb port and guitar connected with 1/4 inch cable.
SiSoftware Sandra
Computer
Model : HP HP Pavilion dv6 Notebook PC
Workgroup : WORKGROUP
Host Name : daniel-PC
User : daniel
Processor
Model : AMD Phenom(tm) II N830 Triple-Core Processor
Speed : 2GHz
Cores per Processor : 3 Unit(s)
Type : Mobile, Tri-Core
Integrated Data Cache : 3x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 Cache : 3x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
Computer
Mainboard : HP 143F
BIOS : HP F.08 06/10/2010
Bus(es) : ISA PCI PCIe USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 3.75GB DDR3 SO-DIMM
Chipset
Model : HP RS780/880 Host Bridge
Front Side Bus Speed : 2x 1.8GHz (3.6GHz)
Total Memory : 128MB
Shared Memory : 320MB
Channels : 2
Memory Bus Speed : 2x 400MHz (800MHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Total Memory : 4GB DDR3 SO-DIMM
Channels : 2
Memory Bus Speed : 2x 667MHz (1.33GHz)
Memory Module(s)
Memory Module : Micron 16JSF25664HZ-1G4F1 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (10-10-10-27 5-37-11-6)
Video System
Video Adapter : AMD M880G with ATI Mobility Radeon HD 4250 (40 SM4.1 500MHz, 320MB 800MHz 32-bit, Integrated Graphics)
Graphics Processor
STREAM Processor : AMD M880G with ATI Mobility Radeon HD 4250 (40SP 500MHz, Integrated Graphics)
Peripherals
LPC Hub Controller 1 : HP IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : HP SB700/800 LPC host controller
Audio Device : HP IXP SB600 High Definition Audio Controller
Audio Codec : Integrated Device Tech 7605h
Audio Device : HP RS880 Audio Device [Radeon HD 4200]
Disk Controller : HP SB700/800 SATA Controller [AHCI mode]
USB Controller 1 : HP SB700/800 USB OHCI0 Controller
USB Controller 2 : HP SB700/800 USB EHCI Controller
USB Controller 3 : HP SB700/800 USB OHCI0 Controller
USB Controller 4 : HP SB700/800 USB EHCI Controller
USB Controller 5 : HP SB700/800 USB OHCI2 Controller
USB Controller 6 : HP SB700/800 USB OHCI0 Controller
USB Controller 7 : HP SB700/800 USB EHCI Controller
SMBus/i2c Controller 1 : ATI SB800 SMBus
Printers and Faxes
Printer : Nitro PDF Reader Driver (600x600, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Network Services
Network Adapter : Anchorfree HSS Adapter (Ethernet)
Wireless Adapter : Atheros AR9285 802.11b/g/n WiFi Adapter (802.11g (ERP), 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 64%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.4
SiSoftware Sandra
Computer
User : daniel
Processor
Speed : 2GHz
Computer
Mainboard : HP 143F
Chipset
Channels : 2
Chipset
Channels : 2
Memory Module(s)
Video System
Graphics Processor
Peripherals
Printers and Faxes
Network Services
Power Management
Battery No 1 : 64%
Operating System
