Pro Audio 9
  • Thread starter Thread starter Redkid53
R
Redkid53
Is there a way to transfer all my files from Home Studio 9 to Pro Audio 9? I screwed around switching the folders and stuff, and that worked, but then when I opened the song, I had to find each individual wav file, located in the wav data folder. I have a least 1gig of wavs, this way would take too long to do. Anyone know any shortcuts?
I'm not familiar with Home Studio 9. Does it have the ability to save "bundle" files. If it does then save your work as a bundle (.bun), and then open the .bun file from PA9. Should transfer everything.
Sounds like you have the two apps on the same computer. Home Studio and Cakewalk each have probably established a distinct Audio Data file. You need to determine what these are, then copy all the files from Home Studio's Audio Data folder into Cakewalk's.
I presume that you'll probably be using Cakewalk and stop using Home Studio, so once you have done this you can uninstall Home Studio and remove its (now no longer used) data directory.
Saving them as buns in HS, then opening the buns and saving the projects in Cakewalk will accomplish the same thing but with a lot more tedium.
The manual or help system can tell you where the setting for this can be displayed and edited within Cakewalk. It might be under the Options dialog box or perhaps under the audio settings.
