J
James HE
a spoonfull weighs a ton
How close to zero can/should I push the meters on mix considering that there will be matering done and mixing to .wav files? How should I mix with the final master in mind? For instance, I'm working with Cubase, should I simply turn down the master fader to where there are no peaks throughout the song, increasing the level and add compression in mastering? Should I be compressing the mix any? Or maybe ride the master fader a bit? I have simply plugged in Waves RCL on the master buss, just turning the defalt setting on to get the limitimg. The limiting did work, I didn't have to squash the volume. But I wonder if I should not use ant effect on the master buss at all.
I may be mastering the project myself,
or it will be sent elsewhere,
Depends on what kind of budget the band come up with.
-jhe
-jhe
