Preamp/Torpedo in Fx Loop
  • Thread starter Thread starter frank1985
F
frank1985
Active member
Guys, I’m looking for advice on how to best incorporate a Kingsley preamp (Juggler) into my fx loop, along with a torpedo cab (Juggler > TC. What is the difference between connecting to the send or return, and what is recommended?
Edit: ok, I’ve looked into this, and assuming I’ve understood things correctly, the send is from the amp’s preamp - connecting this to the Juggler > Torpedo (with drives front of amp) and then to my interface would bypass the Poweramp, am I correct?
The return connects directly to the Poweramp, right? Connecting straight to this input with the juggler bypasses the amp’s preamp, and the juggler acts as the pre.
In the second case, does this mean that front of amp effects will not work and will therefore need to be routed straight into the Return preceding the Juggler and Torpedo?
