D
darkecho
Ok, Theoretical Situation here,
Say I have a Firepod with 8 preamped ins, those preamps are pretty low quality compared to say, oh I dunno, an amazing 100,000,000$ preamp.
Now, this is all the equiptment I have right? my interface has built in pres that are nothing compared to my expensive preamp, but what will happen to the sound if I have a mic go into my amazing$$$ preamp and then into the firepod to record into my DAW?
I will essentially be double-preamping the signal, or does it not work like that?
It seems like you would not want to color the signal coming out of your expensive pre with the firepods pres, am I correct?
say this is true, is there a way to bypass the firepods preamps, so that you can just use the firepod as a pure preampless interface? or would you need to just have a soundcard that does not have built in pres?
so basically, what happens if you run an already preamped *pristine* signal through a dumpy preamp?
