power supplies for midiverbII/MicroverbIII
  • Thread starter Thread starter LemonTree
LemonTree
LemonTree
Suck 'em and see!
Just bought a microverbIII and a midiverbII from ebay....no power supplies......can I use any regular 9V wall wart for these? Anyone using either unit able to tell me the Va output or the Mw output would be a great help thanks
Alec
The Midiverb II uses the Alesis P2, part #7-40-0902 for $19.99 from Alesis.
The Microverb III uses the Alesis P3, part #7-40-0903 for $19.99 from Alesis.
They are both 10VAC at 7.5 VA, but have slightly different end-plugs.
You can get two P3s from Musician's Friend for $12.95 each and just put a different sized end on one of them for the Midiverb II (Recommended).
http://www.musiciansfriend.com/srs7...4224503386/g=home/search/detail/base_id/55439
Don't use a DC power supply or you'll fry the units.
You can call Alesis parts in USA at 310-301-9563 or email to parts@alesis.com
Or
ALESIS UK LTD
Phone: +44 1252 341 400 • Fax: +44 1252 353 810
nbutcher@alesis.com
:cool:
As long as you match the volts, a/c vs/dc and match or exceed the va rating, you might find it at the local RadioShackQuickieMart.
If they have the multi-plug ends it might save you a 32ga wire solder session.:)
